#1 |
![]() I needed some fixture clamps but they are very expensive.
So I bought Harbor Freight Clamps on sale $19.95 and some 16mm shoulder bolts welded them to the cut off clamps. I will probably cut the shoulder bolt off some but these work so good. I was able to get 8 of these clamps.
The Following User Says Thank You to pinballlooking For This Useful Post: | Daox ![]() |
