Old 12-28-20, 06:50 PM   #51
solarhotairpanels
Originally Posted by SimpleManLance View Post
I just checked out both your systems. very cool! On your drain back system, don't you need some sort of a vacuum break to get the water to drain back into the 6 gallon tank?
I forgot to mention that I went up on the roof and installed a vacum break type valve at the highest point where hot water leaves collectors on route back to drain back tank. This valve allows a pinch of air into piping as water flows by but will not allow water to leak out. Just perfect for the application.
Pat from Warwick, RI
Please Note:
Comments and/or suggestions I make here at the forums on 'your' projects as well as my own have all been carefully and scientifically calculated by 'the seat of my pants'
solarhotairpanels is offline   Reply With Quote
Old 12-23-21, 07:00 PM   #52
skyking
Do you think a single collector would suffice for the average home hot water supplement?
Now I am considering point of use tankless electric heaters, one at each bathroom and at the kitchen, and put two of those zones on a circ pump with timer and put the solar trank system near the other.
I'd go with your drainback system and a modest 30~40 gallon storage.
skyking is offline   Reply With Quote
hot air collector
