Forum: Appliances & Gadgets
12-12-23, 08:54 PM
Hehehe firearm parts! That's so government like...
Hehehe firearm parts! That's so government like the J6 committee still pushing so the Cheeto can never ever ever make anything (great or otherwise) again. Meanwhile, 3d printers selling like Glocks....
12-12-23, 04:12 PM
The printer you linked to looks good for the...
The printer you linked to looks good for the price. You can download many 10's of 1000's of stl files from thingiverse. You can download the Creality slicer app and use it to create gcode - the...
12-12-23, 02:15 AM
Forum: Tools
11-13-23, 03:27 PM
The oil pressure was low and lower when hot.
I...
I looked up the oil that Quincy recommended you use 30 weight. I bought some Quincy oil.
that is 30 weight compressor oil. Now it is very happy I had...
Forum: Energy Storage
10-22-23, 04:37 PM
Makes you wonder how long a heat trap is...
Makes you wonder how long a heat trap is required, perhaps duplicate what you have and place two next to each other; or add another flapper check valve in the cold line entry into the tank.
Simple...
Forum: Tools
07-30-23, 09:48 AM
I got this as a backup and we built an new shop...
I got this as a backup and we built an new shop and my other compressors and not up and running just yet. I am using this compressor as the primary one just for plasma cutting and die grinders.
It...
Forum: Conservation
07-04-23, 05:11 PM
Forum: Conservation
05-30-23, 06:21 PM
Forum: Conservation
05-30-23, 06:00 PM
Forum: Tools
03-04-23, 05:25 PM
02-01-23, 12:48 PM
01-06-23, 01:20 AM
Universal Air-Source Heat Pump Controller
I came across a remarkable, inexpensive device that can make building a Homemade Heat Pump much easier. In the "Manifesto" thread, we hit a bump because in our attempt to design a simple cheap...
Forum: Other Improvements
12-02-22, 04:19 PM
Chevy Volt Upgrade
We have a 2017 Chevy Volt Premier that is fueled about 50/50 with sunshine.
Last week we put 3910 miles on to got to Utah from Iowa and noticed that my wife had a valid point. The heat for your...
11-15-22, 10:32 AM
Hello Eco-Renovators
Thought Id give you a...
Thought Id give you a up-date on the DIY 5ton shop ground source heat-pump. It is Nov. 15/2022 and -2 Deg C outside with snow flurries. A couple weeks ago I had moved the...
Forum: Tools
10-21-22, 03:21 PM
Harbor Freight welding table clamp.
I needed some fixture clamps but they are very expensive.
So I bought Harbor Freight Clamps on sale $19.95
and some 16mm shoulder bolts welded them to the cut off clamps.
I will probably cut the...
10-19-22, 11:44 AM
Oil change Panasonic 5KS225EAA21
Hi,
my conversion project is going on. Since the Mini Split AC System I'm using was a long time out of service (to be honest, it is almost new but was years without refrigerant) I assume, that the...
Forum: Tools
10-02-22, 07:22 PM
I filially got my fixture table welded up.
It...
It is supper flat. I cant wait to make some fixtures for it.
I bought a bunch of Harbor Freight clamps that I will cut up and make table clamps out...
08-21-22, 02:44 PM
08-04-22, 02:12 PM
Thanks for the info; what you're describing is...
Thanks for the info; what you're describing is the one thing I've heard from other sources as a possible cause.
Since sending the original message, I paid a guy come out to check both my systems....
08-04-22, 11:34 AM
I had a valve problem year back that had the...
I had a valve problem year back that had the exact same issues ... basically letting more by then it is suppose is what I was told. then can only be verified with testing the pressure while at rest...
08-04-22, 06:04 AM
07-31-22, 10:57 AM
Those little sealed lead acid batteries usually...
Those little sealed lead acid batteries usually don't last long even in the best of conditions, they're built to be cheap. Not to mention largely obsolete when lithium batteries are cheaper nowadays....
07-27-22, 03:38 PM
Forum: Lawn and Garden
06-26-22, 07:34 PM
06-19-22, 04:40 AM
We have on roof PV, which keeps out a lot of...
We have on roof PV, which keeps out a lot of heat. We also have mvhr, which automatically heat excahnges or bypasses- it doesn’t handle huge amounts of air though. We keep windows closed on hot...
