Prev Previous Post   Next Post Next
Old 10-03-09, 06:29 PM   #1
Default Sanyo 24KHS72 AC/HP DIY install project
I've been reading about this gizmo for about a year now, and I'm impressed.
24KHS72 - Sanyo 24,200 BTU Heat Pump Air Conditioner Kit
I've placed my order and it should be here in a few weeks.
In the mean time, I need to get ready with some tools and education.
I've already picked out the location for the outdoor unit and built the pad.
Moved the water tap down the wall a few feet, leaving a nice hole for the 230VAC power.
As you can see from this chart:
Woburn Weather - Massachusetts - Average Temperatures and Rainfall
The mean temperature is only 25 deg F. during our coldest month of the year.
So, if this thing will put out adequate BTUhs of heat when it's 17degs out,
we should be warm as toast this winter.
(They say, it will do 70% at Zero degrees F. That's 20,300 BTUh)!
I'm going find out if this is true, if it gets that cold this winter!
I'll post more as I go along.
Cheers,
Rich
Edit: Adding informative charts.
Here's the 'After' picture.. So you won't have to read all these pages..
Flow chart:
Inside unit:
Outdoor unit:
Last edited by Xringer; 11-28-09 at 12:46 PM.. Reason: Adding chart.. and now some pics of diagrams
CudaNet (10-31-13)
