10-04-09, 08:05 AM | #9 |
Thanks
From what I've been able to glean, Sanyo is one of the better brand names (for ductless).
And, I was able to get very familiar with the Sanyo 24KLS72 AC-only unit that we had installed at work. It's a super AC and like you said, 'can't even tell that it's running'.. After 30+ years of waking up to the baseboard pipes pinging at night, on our forced-hot-water-by-oil system, a reduction in noise level is most welcome! ~~~ The 20' line-set that comes with the kit I'm getting might be a bit too long. I found out that the minimum length is 10', so I'm thinking about cutting them down to around 13 to 16 feet on install day. After seeing the very poor job our HVAC guys at work did on the 24KLS72 line-set install, I'm thinking of buying my own Sears flare tool and DIY. Sears.com I see the manual refers to a 'special R410A flare tool' and "RIGID", but there just isn't enough info about which tool I need. Sears has a bunch of them, but I need some tips on what to look for.. Thanks, Rich Edit: It seems I will need a 37 degree flare kit.?. Summit SUM-900311 - Summit Racing® 37 Degree Flare Tool Sets - Overview - SummitRacing.com Not too cheap looking. Everything else I found cost way too much. I saw where one guy converted his 45 deg to a 37 deg in his shop.. Last edited by Xringer; 10-04-09 at 09:49 AM.. |
Tags |
air conditioner, diy, heat pump |
