02-15-19, 12:17 PM | #21 |
Nice find! We'd like to see some pictures if you have them.
02-18-19, 06:38 AM | #22 |
Green Room (formerly walls were green)
Hallway Dining room is a mess |
02-18-19, 06:44 AM | #23 |
The white paint on the floor in the green room is water based it appears so when I sand the house it should come right up. In the left door of the hallway you can see the fake wood floor they put in, it looks like it sits right on top of the hardwood but have to move a bunch of furniture which means I need to finish the green room and the library.
Pulling that carpet up was pretty disgusting, never want carpet in another house. Edit: I lied about the car, I was finally talked into buying a more fuel efficient vehicle (price was good) but still have my truck for off roading and hauling sheet-rock or whatever else I need to haul. With as many miles as the truck has (300,000) need to have a daily driver that won't break down suddenly (hopefully.) |
03-04-19, 08:37 AM | #24 |
Got to the library this weekend. There is a madness to my method:
Before (dirty nasty carpets, we hates it precious) After: Still have the living room carpet to remove and the laminate from the master bedroom then need to rent a roll off or find somewhere to recycle the old carpet. |
03-07-19, 09:52 AM | #25 | |
I was also told by the actual trash hauler guy that if I could get things down to a load the size of the garbage cart, I could bribe most of their guys $5 to take each additional trash can load of stuff if I was there to toss it in the trash can, and they'd just run the machine to dump it in the truck from the cart. ..so you if you are around when those guys are coming by, it might be worth asking. If you are at work or otherwise away, it's probably just worth calling the hauler. |
03-07-19, 10:45 AM | #26 | |
Last couch I got rid of I tore it apart and used one of the cannister's to throw pieces away for no extra charge but it was a lot of time and work. Took almost 3 weeks to get rid of it all. Plus a bunch of other old junk that I want to clean out of the basement. If I'm not using it and it's beyond repair I want to get rid of it. |
04-20-19, 06:08 AM | #27 |
Now doing laundry every other week (and still less than before) and on Tuesday my refrigerator decided to die. It was a 22 cf refrigerator with freezer on top. Since it was an emergency I bought a cheap 3.3 cf refrigerator from the hardware store. Previously I was using an average of 14 kwh/day. Last couple days have averaged 9 kwh/day. Curious to see if this trend continues.
The question is can I live with a super small refrigerator or will it drive me up the wall to the point of buying a larger one. Only time will tell. I still have the 50 odd year old deep freeze that I'd been planning on getting rid of. Sadly it won't go for the time being since the little fridge doesn't have a freezer. All but the living room carpet is gone. Need to get rid of the couches next and start tearing that up. Then I can rent a floor sander and sand the living daylights out of the floor and refinish them. |
05-09-19, 02:35 PM | #28 |
Electric usage this last billing cycle was less than 400 KwH. Lowest I've ever had. Unfortunately by the end of the month I'll be putting the window ac's back in since I haven't gotten to where I could replace the central ac. Still considering a mini-split but they are ugly and I want to sell the house so not sure the next owners would appreciate the look. Regardless am probably going to have to replace the furnace as well. If I get the job I just did the first interviewed for at the rate I'm asking some projects will speed up. If not I'll just keep crawling along. Still trying to get my truck fixed as well which is holding things up.
The Following User Says Thank You to zorander6 For This Useful Post: | Daox (08-05-19) |
05-24-19, 09:12 AM | #29 |
Finally replacing the sliding glass door, window in the living room which is huge, and the kitchen window which has needed to be replaced for years. Spending a little more than I wanted to on them but hopefully they will be worth the cost. Can't afford to do the rest of the house yet but hopefully in a year or two I'll have the cash saved up to do some more. Just replacing the sliding glass door should help keep the house cool without AC considerably.
Still haven't put the window AC's back in. With all the rain we've been having I haven't really needed it though there have been a couple days that were warmer than I like. Hoping I can last out another couple weeks without the AC's. |
06-05-19, 09:07 PM | #30 |
Gave in to the dark side yesterday and put the window AC back in the bedroom. Currently it's the only room that is cooled and I keep the door mostly closed (because cats are annoying.) Also had to turn the dehumidifier back on because of all the rain. 91 F today, supposed to rain tonight and be cooler for a couple days so might be able to turn the window AC off. It's still as hot outside as it is inside so will have to leave the AC on tonight to be able to sleep.
Looks like I'll be right at 500 Kwh this month. Depends on how much I need to run the AC to sleep. |
