Old 10-12-09, 08:08 PM   #11
Wow, I read this and felt guilty for letting my little Armite micro project sit dormant all summer..
Check out my heat sensors up top. I epoxied the heat sensors inside of metal tubes and made them look like blasting caps!!
Anyways, the built-in basic does not have floating point, so it's a PITA for a non-programmer like me.
Maybe I'll get back on it after the snow comes..
Old 10-12-09, 09:33 PM   #12
ldjessee
Thanks for posting this picture!
ldjessee is offline   Reply With Quote
Old 10-12-09, 09:54 PM   #13
Ron22
Question about the SparkFun Electronics logger.
How hard is it to setup how often it logs data? Can I set it up to log every half hour? With this rate how long before it filled up the data card?
Ron22 is offline   Reply With Quote
Old 10-13-09, 07:25 AM   #14
Are you thinking about getting an ARMite unit?
Dealer:
Coridium Corporation - Programming
Example program info:
EE20N: Hacking Stuff (Wtr'08) — SOEL
Old 10-13-09, 09:19 AM   #15
ldjessee
I have a question Xringer, did you have a particular reason you mounted it to a sheet of metal? Didnt know if you trying to shield it or some other reason other than you had a piece of sheetmetal and it seemed the thing to mount it to.
I have a finished basement and the temperature range from downstairs to upstairs can be significant. I would like to gather some data and see if it is as much as I think it is, or if it would be worth it to rig some kind of switch to run the fan to circulate air.
Old 10-13-09, 09:51 AM   #16
The metal sheet was used to give the parts a solid platform.
I wanted to install this down in the basement, so I used a plastic storage box
(like Tupperware) as a dust cover.
Mounted the PCBs on aluminum and bolted the sheet and connection
strips on the inside of the storage box cover.
I will screw the cover onto the wall, and the 'bottom' of the storage bin
will just clip onto the cover. I'll cut some notches for the I/O wires.
I also got one of these.. SparkFun Electronics - Serial Enabled 16x2 LCD - Red on Black 3.3V
Want to display temperatures upstairs.
Old 10-13-09, 06:49 PM   #17
Ron22,
You can change the logging interval to log around 250 tumes per second (more if you log fewer inpits) to 1 log per second by changing a text file which is read at boot up.
You'd have to modify the firmware to include some wait state loops, which is not a huge deal, but with all my projects was just too much resistance.
As microprocessors go, the arm is a good one and pretty powerful, but overkill if you want to read data at 30 minute intervals. This is actually what I wanted to do.
There's the AVR butterfly, which I think would be better.
You should check out this link.
And then this link.
Runs seven years on a tiny battery.
I think this is the answer to your prayers.
Regards,
Old 10-13-09, 07:45 PM   #18
Ron22,
And then this link.
Regards,
Old 05-22-10, 11:29 AM   #19
cmroseberry
The least expensive datalogger I have found is an OM-44 from Omega Engineering for $104. Temperature sensors for this logger are $33 (OM-40-C-HT-B). Omega also has a wealth of free tech literature about measurements and data acquisition. The OM-44 does not yet have a Windows 7 driver. I have several OM-44 set aside for field testing my WarmSpring pool heaters. A small cheap data acquisiton system worth considering is a DATAQ DI-194RS. DATAQ offers these as very inexpensive start-up kits. Unlike the dataloggers, this data unit cannot stand alone; it has to be connected to a computer. For small signals, like thermocouples, the signal will have to be amplified to give good resolution for the data aquisition system's 0-10 V measurement range.
After pulling my hair out for years trying to get rid of noise on thermocouple signals, I now favor RTD's and temperature sensing integrated circuits such the Analog Devices AD-592. These transducers are inherently less susceptible to noise.
cmroseberry is offline   Reply With Quote
Old 05-23-10, 11:07 PM   #20
Default Thermocouple noise, 1-wire + Arduino
cmroseberry,
You are quite right about the noise in the thermocouples. I was able to deal with this in post-processing. I wrote a macro in Excel that would average over several readings. This smoothed things out quite a bit.
Also available is 1-wire sensors. They are accurate, and can be easily interfaced to an Arduino. In fact, 1-wire interface code is included in the Arduino development system.
butterfly, data, logger
