Old 01-31-18, 08:01 PM   #1
sunspot
Default nest camera
There was a Great Gray Owl in the yard the other day which got me thinking (again) that I'd like to put a nesting platform up to hopefully attract a nesting pair of raptors. And if I'm going to climb a tree to do this (something I'm equipped to do) I might as well include a camera. But... while I don't mind climbing to put things in place I want no part of climbing to change batteries or memory cards. Thinking this has been done before and a solution would be easy to find I turned to google only to learn there's a home security camera with the name 'nest cam' which renders googling ineffective for someone actually interested in putting a camera in a bird's nest. So while my question is totally off topic y'all have proven a resourceful group with a wide range of knowledge and experience so I'm asking here: What is a typical nest camera setup with power and storage remotely accessible?
Thanks,
Old 01-31-18, 10:55 PM   #2
There are plenty of outdoor IP cameras available. Just run a long wire to power it.
sunspot (02-01-18)
Old 02-01-18, 08:14 AM   #3
sunspot
On further research, is there a solution that doesn't require a subscription, account, user fees, or wifi? I'm thinking more of a power cord and remote hard drive. I don't need live streaming.
Old 02-01-18, 09:44 AM   #4
Search for Ethernet connected outdoor cameras. Most of those will support PoE as well. Then use a Raspberry Pi as your own server.
sunspot (02-02-18)
Old 01-07-19, 08:32 PM   #5
sunspot
Originally Posted by RalphWilkins View Post
Raspberry pi will be a good option for you. You can do a lot of customization with it too
Thanks Ralph. I've got a Pi running Naturebytes software now. It's in the house for testing and waiting patiently until I get the nest site prepped. Works great. I've yet to add the PIR sensor but that shouldn't pose a problem. I do have a question though. What about audio? Any ideas for adding that functionality to the nest cam?
Thanks,
Old 01-30-19, 09:15 PM   #6
sunspot
The microwave proximity sensor arrived. Works without issue (lower right in photo). One step closer...
The Following User Says Thank You to sunspot For This Useful Post:
Daox (02-08-19)
Old 02-01-19, 08:59 PM   #7
where2
DIY Geek
Certainly, the photos from a 5MP Raspberry Pi camera aimed at a nest should be quite impressive!!
For those without such high skills in electronics and Linux, a Loosafe 1080P outdoor wifi camera (LS-C6) will probably exceed your expectations. I run mine with MicroSD cards for onboard storage which I can then download from my PC (on the same network). You can choose the frequency it snaps a still photo, and set recording hours for video. You can set them to push images to a FTP server, if you're computer savvy. I've chosen the ones with 8mm and 12mm lenses to limit my wide angle views, although I did purchase one with a zoom lens to allow me to choose which fixed focal length will work best in a particular install location. These cameras basically require 12V power, and wifi (or a wired ethernet connection). I use these cameras to snap the sunrise photos I miss taking every morning, because life doesn't always afford the chance to stop and watch the sunrise.
sunspot (02-01-19)
Old 02-04-19, 09:31 PM   #8
Another option that recently came out is the ESP32 camera.
https://hackaday.com/2019/02/02/cheap-esp32-webcam/
Daox (02-08-19)
