Old 04-28-17, 08:54 AM   #21
pinballlooking
pinballlooking's Avatar
I have experimented with tuning them off and back on. I have found that I use more energy than just leaving them on all the time.
Now we sometimes turn it down a couple degrees the when the boys come back home the will change it a couple degrees this does save some energy.
Solar Install 12.5 Kwh-
Mini Split installs -
EV Chevy Volt -
Old 04-28-17, 10:11 AM   #22
oil pan 4
Land owner
The reason I went with a 9,000btu split in the bed room is my wife works night shift so that one runs all day.
The hottest days the room would warm up to about 85'F with a 6,000btu window unit.
Old 04-28-17, 10:18 AM   #23
pinballlooking
We have three Gree 9,000 BTU 27 SEER Terra series. They are a great fit for a bedroom.
They will keep it as hot or cool as you want and do the job quietly enough to still sleep.
These all run 24 x 7.
EV Chevy Volt -
Old 04-30-17, 01:14 AM   #24
Just One More
Just One More's Avatar
I gave to agree with your points. They are excellent.
Just One More is offline   Reply With Quote
240v, air conditioner, inverter, seer, split
