11-17-14, 08:29 AM | #11 |
That sounds great.
How / what thermostat did you use? I assume its just on a wall switch?
11-17-14, 11:20 AM | #12 |
Yea, it replaces a regular wall switch, and installation was about that easy. Its a line voltage thermostat, specifically a Marley MS26, found on amazon for $10 plus $5 to ship. Temp differential is advertised as 5 degrees, but with the switch fairly close to the fireplace, it acts like 3.
