Old 01-10-19, 01:22 AM   #1
Default Mini-Split, blinking red light....
Hello All,
My trusty Sanyo Mini-Split has blinking red indicator, and it is producing no heat. This may last for many hours, until I turn it off.
It is an intermittent condition, and If I turn the unit off completely and wait several hours, turn it back on, it will function. However this above mentioned behavior seems to return..
It is Model Sanyo KS0971, as I recall. It is a 3/4 Ton unit.
Earlier this year, I thoroughly cleaned the outdoor unit coils. And I also regularly vacuum and blew out the indoor unit.
Any help will be greatly appreciated.
Old 01-10-19, 03:57 AM   #2
stevehull
Steve Hull
My son had a similar problem and we found out the unit had a small leak at the flare (sniffer found it). So we sucked gas out, re did flare (my fault as I was not as careful as I should have been originally) and filled using weight not psi.
Interestingly, the unit worked OK for cooling, but not heating. The tech at Gree told me about checking for a leak. Trying to get schematics for these units is tough.
Now works like a charm. I hope it is that simple for you.
Thanks for ALL your posts in the past!
Steve
Old 01-11-19, 01:27 PM   #3
Steve
Thanks Steve for your response,
I think my problem may be different than the one you described:
* There may be a slow leak as you suggested, but I set up the unit very carefully seven years ago. Of course this doesn't mean that it isn't leaking now.
* My unit is not blinking red all the time. It may go several days or even weeks before the pattern re-appears. Then if I shut it completely down for some short period of time, turn it back on, it works exactly as expected.
* It's the intermittent aspect that has me stumped.
I was previously experiencing a gradual decline in performance, but then discovered that the fins on the outdoor unit were seriously blocked, and I used foaming fin cleaner (really works well) and water jets from inside the unit, squirting out. Ended up with shiny clean and clear fins. That completely remedied the performance decline.
I do all the standard vacuuming of the fins on the indoor unit on a regular basis. I also used high pressure air to blow out any dust from the fins. Almost none came out which made me wonder if either I had done a spectacular job all along, or my pressurized air was not getting to places that really needed cleaning.
Right now I am suspecting that the fins of the indoor unit needs cleaning.
Here are a couple of videos of that process. The first video is thorough, the second video is more rigorous, and features a "muck collector" that could be easily fabricated by any determined Ecorenovator.
FIRST VIDEO:
SECOND VIDEO:
...and another which seems to be a training video for a mini-split cleaning company, to fill in any gaps that an Ecorenovator might have:
Your thoughts??
Old 01-10-19, 06:43 AM   #4
What ever happened to the other one? I basically threw in the towel on the general purpose control. Too many special needs and lack of support to help program and standardize.
Here's a general sanyo error codes list:
Sanyo Air Conditioning Fault Codes
Found your manual. I will attach. Troubleshooting starts at page 42. Good luck
Old 01-11-19, 01:30 PM   #5
[QUOTE=jeff5may;60453]
Thank for that, but my unit doesn't have an alphanumeric indicator, only flashing lights.
The PDF may answer my dilemma. Thanks
