How does that compare to other pumps as far as GPM per watt goes?
Does your inverter give a duty rating or anything else like that?
I would think if it was seeing to much surge in an hour it would over heat and trip a thermo over load switch, another option might be to see if you can adjust the pump so it has longer cycles, so it fills with more water before kicking on.
Are these a trash pump, or a simple sump pump? because we use a trash pump at work in a pit to pump out mud (granite counter top shop) and that over run feature sounds nice to make sure all the water gets pumped out.
