Hello Eco-Renovators
Thought Id give you a up-date on the DIY 5ton shop ground source heat-pump. It is Nov. 15/2022 and -2 Deg C outside with snow flurries. A couple weeks ago I had moved the controls from Air-conditioning to Heating and the homemade heat-pump over the past 8 years has kept me comfortable in the shop. No maintenance has been needed. WoW!!
Pretty outstanding I would think!!
Randen
