Originally Posted by dguzzi
Please think very small flow rate. The air pressure is from an aquarium pump. Pressurizing a small vessel with ice and water, then flowing to a loop and returning. The check is to prevent flow to the return, I think tiny head on that return so very sensitive check valve.
But how do you want to return the water to the vessel that's pressurized by the air? I don't understand how your system is supposed to be working.
Could you draw a small diagram?
