Originally Posted by AirSepTech
Anyone thought of modding one of these for home use? First time I've seen this.
If you track back in the manifesto thread, there's a link to a company that sells similiar product, but non-marine. The "marine" part puts a premium on it that is not needed for home use. I believe I commented on it being a good source of HVAC supplies.
Not exactly cheap, but should be easy. I have been looking for basement heat, maybe hack a window unit, 1K gal. solar drainback tank in ground. Found a 20k btu R22 unit for $600 new. But I never have enough hacktime!
If your hack-time is limited, you'd be better off getting a mini-split to heat your basement.
The installation time is low and the efficiency is high, and the price you're considering is about equal.
Xringer has a
good thread on the procedure.
Regards,
