Forum: Conservation
11-09-13, 09:06 AM
Freus (http://freus.com/) has already done most...
Freus (http://freus.com/) has already done most of the work on a larger basis. System does get great efficiency but isn't without it's issues. Homewoners don't want to maintain them or pay to have...
Forum: The Billiards Room
07-26-12, 10:45 AM
No, I'm saying lots of small actions are better...
No, I'm saying lots of small actions are better than no action. Big changes on the corporate or governmental level? Even better! Fantastic! But you have to be realistic about the political process....
Forum: Tools
05-07-12, 11:35 AM
Forum: Conservation
10-03-11, 07:05 PM
Posted By
Angmaar
Very cool. It's a good idea to turn things...
Very cool. It's a good idea to turn things off/slow them down when you don't need them. I just found someone who did something like this for android (you need a rooted phone though)here...
Forum: Solar Power
09-22-11, 08:51 AM
03-30-11, 04:06 PM
A Better Temperature Controller...
In post # 631 (http://ecorenovator.org/forum/geothermal/484-homemade-heat-pump-manifesto-64.html#post12506), I documented how I made a temperature controller from a line-level bi-metallic controller....
Forum: Tools
11-26-10, 11:53 PM
Energy Plus = Energy Simulation Tool
("Energy Simulation Tools" should probably be a Sub-Forum. I have compiled a pretty big list of other tools that Ecorenovators might want to try.)
I just came across a computer-based energy...
10-04-10, 01:00 PM
10-04-10, 11:12 AM
09-24-10, 04:01 PM
To answer the titular question, no. There's no...
To answer the titular question, no. There's no correlation between how much you produce, and how much you ought to consume. Even net oil exporters should try hard to conserve oil, because every...
Forum: Conservation
09-07-10, 11:23 PM
Forum: Renovations & New Construction
09-02-10, 11:54 AM
For the outside you should seal the cracks, I...
For the outside you should seal the cracks, I found that 6" wide butyl rubber tape with foil backing for going around sky lights works really well for going over cracks after you repair them either...
Forum: Conservation
04-02-10, 06:40 PM
02-09-10, 09:36 AM
Forum: Other Improvements
11-11-09, 06:01 PM
How to repair concrete
I found this today. Some great DIY info on how to repair concrete. It covers cracks, driveways, holes, broken corners and more.
How to Repair Concrete...
Forum: Forum News & Feedback
09-19-08, 12:18 AM
