Forum: Solar Power
05-07-17, 05:58 AM
Chevy Bolt
I almost didn't want to like it and we expected it to be a 238 mile range Leaf but found the Bolt to be a really fun car to drive with lots of pep and good handling in a very well thought out car....
Forum: Solar Heating
04-15-15, 09:25 PM
12-10-14, 06:00 PM
Just a thought..
If you are not getting enough pressure running your domestic hot water thru your solar tank, could you possibly turn that solar tank into a closed loop system and run that hot water into the house...
12-01-14, 10:48 PM
sources
Check out these links:
Convoluted Copper (25' x 5/8" No Fittings) | MoreBeer (http://morebeer.com/products/convoluted-copper-25-58-fittings.html)
Bottom of page on this one:
Heat Exchanger...
Forum: Appliances & Gadgets
04-13-12, 10:13 AM
The new monitor came yesterday.
Amazon.com:...
Amazon.com: ASUS VS248H-P 24-Inch Monitor - Black: Computers & Accessories (http://www.amazon.com/ASUS-VS248H-P-24-Inch-Monitor-Black/dp/B0058UUR6E)
The LED...
02-19-12, 05:53 PM
R407C is a blend of three HFC refrigerants...
R407C is a blend of three HFC refrigerants designed to give it properties similar to R22. Given it's HFC the oil is likely to be POE.
HC's will work with POE oil, however it is mightily...
02-16-12, 11:17 PM
A couple of things.
Propane is not a drop in...
A couple of things.
Propane is not a drop in for R134a. It has quite a bit higher pressure and finds weaknesses in systems quite quickly. A 60/40 mix of Propane/Iso-Butane gives about the same...
02-16-12, 08:50 PM
02-16-12, 03:06 PM
02-16-12, 11:13 AM
If you have the skill set to integrate an...
If you have the skill set to integrate an electronic feed-back system into your project, why would you want to screw around with unmodified refrigerant-to-air HXs?
Bite the bullet and extend your...
02-15-12, 09:53 PM
02-15-12, 09:34 PM
