Old 02-23-15, 12:42 PM   #1
MarkM66
Default Surplus Alchohol Solution
I have access to a surplus of alcohol solutions. Either 70% Isopropanol or 70% Ethyl Alcohol.
Can someone think of a way to actually use this stuff? Is there a heater that it can be used in to heat a garage or something? Maybe mix it with something else then burn it?
It flashes around 70 degrees F.
MarkM66 is offline   Reply With Quote
Old 02-23-15, 01:51 PM   #2
Piwoslaw
Piwoslaw's Avatar
Sorry for the off-topic, but this is the first time I see someone complaining that they have too much alcohol and don't know what to do with it
Seriously: Maybe mix it with gasoline to clean emissions?
Old 02-26-15, 09:27 AM   #3
Originally Posted by MarkM66 View Post
I have access to a surplus of alcohol solutions. Either 70% Isopropanol or 70% Ethyl Alcohol...
I think that 70% has too much water to be useful as a fuel.
You could re-distill to a higher concentration of alcohol, and then use it for fuel.
Old 02-26-15, 09:48 PM   #4
philb
Donate them to your local health clinic or Salvation Army or ...you get the idea. Both are excellent disinfectants.
Chemistry labs sometimes use them for burners. You could do the same.
philb is offline   Reply With Quote
Old 02-27-15, 06:08 AM   #5
MarkM66
I actually have received 100% Isopropanol before. With that I would put a few gallons in my gas tank at every fill up. Worked fine.
I don't think this stuff would work as well. Don't really want to risk it. I have put some in my wiper fluid though.
Old 03-05-22, 06:02 PM   #6
dguzzi
It would work as an antifreeze in a geothermal loop or experiments related?
dguzzi is offline   Reply With Quote
Old 03-06-22, 04:38 PM   #7
philb
If you have enough to justify the cost of a $100 stainless steel still, you could always use it in your vehicle. At the current price if $4.75 for a gallon of gas here, that's what I'd do.
Old 03-10-22, 03:13 PM   #8
Uhmm anything above about 50 percent will burn.
Old 03-10-22, 08:46 PM   #9
philb
I’d want the alcohol as close to 100% as I could put it in my vehicle because some moisture and water will fall out in the tank. I got the old Briggs and Stratton engines to run on 60% alcohol easy enough by adjusting the mixture screw.
